RME 4.2 / configuration compare problem
robetrem
RME always flag the parameters associated with the
banner and all parameters that follows it as a delta between 2 images.
Any clue ?
yjdabear
Could be due to CSCsu99748
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsu99748
CSCsu99748 Bug Details
Out of sync on banner when running config fetched by TFTP
Symptom:
Device marked as out of sync even though show start and show run are the same. The diff viewer shows that the difference for the configs are due to multiline banners for "banner exec" and "banner login"
Conditions:
Appears to affect LMS 3.1 only - LMS 3.0.1 and LMS 2.6 have been observed to be unaffected.
Latest running config is fetched using TFTP protocol. Telnet and SSH not affected.
Banners configured for "banner exec" and "banner login". For example:
banner exec "
*****************************TEST*******************************
banner login "
Workaround:
Use telnet or SSH to do fetch the running config instead.
Or, use the exclusion commands to exclude all banner config if the banner is not a necessary config to be monitored.
Status
Fixed
Severity
3 - moderate
Last Modified
In Last Year
Product
CiscoWorks Resource Manager Essentials
Technology
1st Found-In
4.2
Fixed-In
4.2
4.3
Yes, this is the bug.  It is fixed in LMS 3.2/RME 4.3.
