Reza Sharifi Fri, 12/18/2009 - 09:42
  • Cisco Designated VIP,
    2017 LAN
You can use reload slot stack-member-number to reset the stack member.
but, you should always use the same IOS version for the entire stack
form the config guide:
All stack members must run the same Cisco IOS software version to ensure compatibility in the stack protocol version among the members
Here is more info:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_50_se/configuration/guide/swstack.html#wp1189553
Use a Tar file to upgrade the entire stack and reboot.
Reza
pmpesha Fri, 12/18/2009 - 09:58
Thanks Reza, I already know the basics of stacks witches.  What I usually do, is upgrade with tar file and then reboot the entire stack.  I will test the reload slot stack id command in the lab to verify how effective it is.  All I want to do, after downloading and extracting the tar file, is to reboot the primary switch, and once that is up, proceed with rebooting the secondary.  I know after rebooting the primary, we will have two versions of IOS, will this be an issue before I reboot the secondary?  Thank you.
Reza Sharifi Fri, 12/18/2009 - 10:12
    2017 LAN
Then, you will have 2 different versions of IOS  and Switches with different major version numbers are incompatible and cannot exist in the same stack.
Also, switches with the same major version number but with a different minor version number as the master are considered partially compatible. When connected to a stack, a partially compatible switch enters version-mismatch mode and cannot join the stack as a fully functioning member.
Reza
