Can CSA produce an application inventory?
Answered Question
Dec 18th, 2009
Can CSA produce and inventory of applications installed on a protected host??
Correct Answer by johuston about 7 years 7 months ago
Yes, if you enable Application Deployment Investigation you will get an inventory of installed applications (what you see under add/remove programs on the PC.)  Additionally, CSA also tracks the processes running on the machine so you will see applications that are not "installed", but run as just transient processes.
Josh
Overall Rating: 5 (1 ratings)
Correct Answer
johuston Fri, 12/18/2009 - 15:23
Josh
