Skype Sip calls not passing digit to auto attendant
johnroche_2
I have a uc520 configured with Skype Sip trunk.
Incoming calls on the trunk are forwarded to the auto attendant.
The auto attendant answer and plays the message Press 1, 2, 3 etc.
However when the calller enters the digits the auto attendant keeps playing the recording.
Any suggestions?
John
I think this issue is something we have seen in CCA when the access code for outbound calls is the same as the leading DID digit that we are looking to fix in a future CCA release. Options are:
1. Use a different access code which may not work for you (such as say 8)
2. Add below CLI and seeif this fixes your issue
dial-peer voice 1003 voip
dtmf-relay sip-notify rtp-nte
6 Replies 6
Maulik Shah
Level 5
Level 5
Does DTMF only fail inbound or outbound as well? To diagnose this further would need below:
https://supportforums.cisco.com/docs/DOC-9830
I know Ted Trentler had this issue but turned out to be a Skype gateway issue - check his comment below:
Dimitris, Skype had a mis-configuration on some of their SIP Gateways.  They changed the config on all of the affected Gateways.
here is a debug log of a test call.
outbound dtmf works fine, I can check my cell phone voicemail no issues.
the issue seems to be invound only
Need the config as well (link sent earlier has info on how to gather this) as I can see that the UC500 is not sending the RFC2833 event in the 200 OK to Skype which is not how CCA normally configures the UC500 for Skype for SIP
Snip of logs:
Inbound SIP INVITE from Skype:
024284: Dec 20 20:07:17.020: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:99051000000666@86.40.234.229:5060 SIP/2.0
m=audio 22438 RTP/AVP 18 8 0 101
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=rtpmap:101 telephone-event/8000
a=rtpmap:0 pcmu/8000
a=fmtp:18 annexb=no
Response from UC500 to INVITE is missing 101:
024622: Dec 20 20:07:17.160: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
m=audio 17974 RTP/AVP 0
c=IN IP4 86.40.234.229
a=rtpmap:0 PCMU/8000
a=ptime:20
Please find attached config.
The sip trunk was configured by CCA
John
Changing the access code isnt really and option.
I added the cli and it worked perfectly.
Thanks very much
John
