cisco ws-c3750g-24ps-s bootloader problem
Answered Question
Dec 18th, 2009
HI,
Swich model is ws-c3750g-24ps-s but it is showing WS-C3750G-24WS-S25/50 and while booting it is like this
not as usual :
i belive this is bootloader issue i tried to upgrade the ios but that does not work it is still showing
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M), Version 12.2 [tting-dsbu2 148]
how i can change this bootloader due to this it is also not going to rommon mode.
Switch#sh ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(52)SE, R
ELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 25-Sep-09 08:32 by sasyamal
Image text-base: 0x01000000, data-base: 0x02E00000
ROM: Bootstrap program is C3750 boot loader
Switch uptime is 1 hour, 0 minutes
System image file is "flash:/c3750-ipservicesk9-mz.122-52.SE/c3750-ipservicesk9-
mz.122-52.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C3750G-24WS-S25/50 (PowerPC405) processor (revision C0) with 131072K by
tes of memory.
Processor board ID FOCXXXXXXX
Last reset from power-on
1 Virtual Ethernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:15:F9:CE:09:00
Motherboard assembly number     : 73-9357-08
Power supply part number        : 341-0108-02
Motherboard serial number       : FOCXXXXXXX
Power supply serial number      : DCXXXXXXXX
Model revision number           : C0
Motherboard revision number     : A0
Model number                    : WS-C3750G-24PS-S
System serial number            : FOCXXXXXXX
SFP Module assembly part number : 73-7757-03
SFP Module revision Number      : A0
SFP Module serial number        : CATXXXXXXXX
Top Assembly Part Number        : 800-25429-02
Top Assembly Revision Number    : B0
Version ID                      : V02
CLEI Code Number                : CNMWR00ARB
Hardware Board Revision Number  : 0x05
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3750G-24WS-S25 12.2(52)SE            C3750-IPSERVICESK9-M
Configuration register is 0xF
Switch#
Correct Answer by Reza Sharifi about 7 years 6 months ago
You are already running IOS version 122-52.SE
mz.122-52.SE.bin"
What are you trying to change it to?
Reza
Overall Rating: 5 (1 ratings)
Correct Answer
Reza Sharifi Fri, 12/18/2009 - 11:38
  • Cisco Designated VIP,
    2017 LAN
mz.122-52.SE.bin"
Reza
Leo Laohoo Fri, 12/18/2009 - 20:19
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Firstly, when you upgrade the IOS to 12.2(50) and later, the IOS will upgrade the bootloader.
Secondly, the WS-C3750G-24WS-S25 is a WS-C3750G-24-PS with a WLC built on top of it.
Can you please explain what is your problem?
surekha.sharma Fri, 12/18/2009 - 22:17
the bootloader was not upgraded even though we installed latest image , due to this bootloader we not able to into rommon mode just see my attchment .
glen.grant Sat, 12/19/2009 - 04:37
  • Purple, 4500 points or more
  So whats the actual issue just that the model number appears wrong ?   The bootloader does not get upgraded with every single version upgrade .  If the display bothers you try a different version  and see if that clears the issue otherwise contact the TAC it may be a cosmetic issue with the code where it is showing the wrong model number.  Also verify you have the model you think it is , usually on a sticker on the back of the switch.
Related Content
