RV016 DHCP assigns wrong IPs
Dec 18th, 2009
I have an RV016 with firmware version 3.0.0.19-tm. The router works fine as long as I manually assign IPs. I have the DHCP enabled and for some odd reason it is assigning IPs that are not even on the network.
The router IP is static (172.16.21.2) with a subnet 255.255.255.0
Why am I getting assigned an IP of 192.168.1.101 on my XP SP3 machine?
Thanks in advance.
Reza Sharifi Fri, 12/18/2009 - 11:45
Hi Raffi,
If it works with static IP 172.16.21/24 range, then take a look at your DHCP scope on the router.  It probably contains 192.168.1.0 address, if yes change it to 172.16.21.0/24
Reza
rtchagatzbanian Fri, 12/18/2009 - 12:06
Hi Reza,
I double checked the DHCP settings. The dynamic IP range is set for 172.16.21.20 - 172.16.21.200.
Raffi
