CCA 2.2 Will Not Connect to UC520
Dec 18th, 2009
  • Bronze, 100 points or more
   Guys,
Another one.... I have done nothing different I used the telephone wizard to setup the basics then each of the different functions to configure the specifics...
After a reload of the device I now receive the attached error message....
Can someone please help or explain what is going on...
Brian
Steven Smith Fri, 12/18/2009 - 13:44
  • Gold, 750 points or more
On the connection page, can you turn off the SSL connection, only use port 80.
I know this isn't a fix, but this should get you back into the box.
