ASA can do Loadbalancing or not?
Answered Question
Dec 18th, 2009
Dear All,
I would like to ask all of you that ASA 5510 and 5520 can do loadbalancing or not?
Best Regards,
Rechard
Correct Answer by Kureli Sankar about 7 years 5 months ago
This is presently not possible with the ASA.
You can accomplish this with PBR upstream on a router.
Two methods to load balance with two ISPs upstream.
1. Add two globals one for each ISP.
2. Translate 1/2 the inside networks to one ISP and the other 1/2 to the second ISP global
3. upstream on a layer 3 device do PBR based on source IP from the fireall.
4. Send globals ISP1 via one link
5. send global ISP2 via the other link
second method:
1. you can use just one global.
2. and load balance between the two links to the ISP on the router.
-KS
Overall Rating: 5 (1 ratings)
rechard_hk Fri, 12/18/2009 - 19:21
Dear KS,
I would like to about internet loadbalancing on ASA 5500 series? is it can support or not?
Note: i would like to ask only one unite for use internet loadbalancing.
Best Regards,
Norung
Correct Answer
Kureli Sankar Sat, 12/19/2009 - 05:58
  • Cisco Employee,
second method:
-KS
