Warning message
Lost password after upgarde
Dec 18th, 2009
I just upgraded a catalyst 3560 with latest tar and it came up with no issues at all and can connect to all devices on it, however cant connect to it with cisco network assistant, the username and password no0 longer works? any ideas what it might have defaulted to?
Thank you
Reza Sharifi Fri, 12/18/2009 - 18:12
  • Cisco Designated VIP,
    2017 LAN
Hi Paul,
I have never used cisco network assistant. Can you use the cli to login?
Reza
Paul_Rydings Sat, 12/19/2009 - 12:48
dont know cisco well so dont know how to login with cli, username and password was blank on setup, guess that was a bad idea anyway
