ACE card reboots in VSS mode
Answered Question
Dec 19th, 2009
Hello, and sorry for the lenghty message.
Yesterday we implemented VSS in our network and encountered a problem with the ACE module that I am trying to resolve.
Here's the hardware layout
two 6509 with the following line cards:
Mod Ports Card Type                              Model              Serial No.
  1   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1329U0TN
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1327T950
  3   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1325SHWN
  5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL1327T9A7
  6   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1328TM43
  9    1  Application Control Engine Module      ACE20-MOD-K9       SAD133201AN
  1  Centralized Forwarding Card WS-F6700-CFC       SAL1327TH0F  4.1    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       SAL1317NUCC  4.1    Ok
  3  Centralized Forwarding Card WS-F6700-CFC       SAL1322R6K6  4.1    Ok
  5  Policy Feature Card 3       VS-F6K-PFC3C       SAL1326T3ME  1.0    Ok
  5  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL1326T183  2.0    Ok
  6  Centralized Forwarding Card WS-F6700-CFC       SAL1327TA00  4.1    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Pass
  5  Pass
  6  Pass
  9  Pass --More--
Switch Number:     2   Role:  Virtual Switch Standby
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1327TG40
  3   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1328TM1R
  4   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1328TQCP
  5    5  Supervisor Engine 720 10GE (Hot)       VS-S720-10G        SAL1327T9B1
  6   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1328TQDS
  8   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1324S80K
  9    1  Application Control Engine Module      ACE20-MOD-K9       SAD133201A3
  2  Centralized Forwarding Card WS-F6700-CFC       SAL1327T9ZY  4.1    Ok
  3  Centralized Forwarding Card WS-F6700-CFC       SAL1327T80P  4.1    Ok
  4  Centralized Forwarding Card WS-F6700-CFC       SAL1327TCWJ  4.1    Ok
  5  Policy Feature Card 3       VS-F6K-PFC3C       SAL1327T9X8  1.0    Ok
  5  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL1326T4QY  2.0    Ok
  6  Centralized Forwarding Card WS-F6700-CFC       SAL1326T2GC  4.1    Ok
  8  Centralized Forwarding Card WS-F6700-CFC       SAL1252EA2J  4.1    PwrDown
  2  Pass
  3  Pass
  4  Pass
  5  Pass
  6  Pass
  8  Not Applicable
  9  Not Applicable
Here's the problem:
On the standby switch 2, the ACE module keeps rebooting. I first thought may be the power was not sufficient, so I checked the power utilization, and I have about 425 watts available.
I shut the power to one of the 10/100/1000 line card and I still had the same problem.
I moved the ACE module to SW1, trying to see if it would follow the problem and it did not have any issues.
I shut down two (2) modules on switch 2, and I still have the same problem.
Here's the log:
odulee
sm(cygnus_oir_bay slot9), running yes, state wait_til_online
Last transition recorded: (disabled)-> stay_disabled (operator_power_on)-> can_p
ower_on (yes_power)-> powered_on (real_power_on)-> check_power_on (timer)-> chec
k_power_on (power_on_ok)-> wait_til_online (reset_timer_online)-> wait_til_onlin
e (reset_timer_online)-> wait_til_online (reset_timer_online)-> wait_til_online
(reset_timer_online)-> wait_til_online xit
N-MSFC-VDR1-PRI#
Dec 19 13:14:50 UTC: %C6KPWR-SW2_SPSTBY-4-DISABLED: power to module in slot 9 se
t off (Module  Failed SCP dnld)
Dec 19 13:14:52 UTC: %SYS-5-CONFIG_I: Configured from console by console
Does VSS shut down the ACE module because it sees two cards in one virtual switch?
Also we have no configuration setting on the either one of the ACE module. We are doing this implementation in phases, and I was planning on applying some basic Load-balancing in a couple of weeks.
I am not sure if this is a Chassis issue or VSS.
Any help would greatly be appreciated.
Correct Answer by rvavale about 7 years 7 months ago
ACE software version A2(1.2) or later and installed in C6k running IOS 12.2(33)SXI or later support VSS.
If the ACE is running lower version then you could see this issue. To resolve this issue you need to upgrade ACE modules.
You could follow below process to Upgrade ACE from EOBC,
You can follow  below process to boot from EOBC where ACE is in Switch 1 , slot 2.
Make sure ACE A2(1.2) or later image is on flash/disk0 on SUP,
Step 1: On Switch configure ACE module to boot from Switch disk0
conf term
boot device switch 1 module 2 disk0:c6ace-t1k9-mz.A2_1_5a.bin
end
Step 2: Power off ACE module in slot 2 by using command,
(Config t) no power enable switch 1 module 2
Step 3: To boot ACE module using EOBC
hw-module switch 1 module 2 boot eobc
Step 4: Then power on ACE module in slot 2 by using command,
(Config t) power enable switch 1 module 2
Step 5: Make sure ACE boots up and has correct version running.
If ACE is already running support version for VSS or if you need any assistance to upgrade then please raise Service request with TAC.
Hope this helps,
Best Regards,
Rahul
Correct Answer by lars.molstad@ec.no about 7 years 7 months ago
This is probable due to old software on the ACE Modules.
I had the same issue with A2(1) release on the ACE, but upgrading software solved the issue.
Have a look at this link: - This states that A2(1.3) is the first supported release for VSS.
http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c72b.shtml
Br
Lars
CCIE 14647
Overall Rating: 5 (2 ratings)
Correct Answer
rvavale Sun, 12/20/2009 - 20:22
  • Cisco Employee,
conf term
end
Hope this helps,
Best Regards,
Rahul
RAMAN AZIZIAN Mon, 12/21/2009 - 06:22
Thank you very much for all your inputs. I am planning on testing it in our lab, so I can schedule the activity to upgrade the software. I had a feeling it was a software mismatch/upgrade, but I wasn't sure which system (ACE/VSS) was the cause.
Now I can go and research the Port channel problem we encountered the same evening. I never seen a problem when you have mis-match QoS to cause the Port Channel not to establish.
Have a great holiday and happy new year!
