Showing results forĀ
Search instead forĀ
Did you mean:Ā
Rate Limiting a 6509 Port
BlueyVIII
I have a 6509 running CatOS v8.2 (I know it's old and am hopefully upgading in Jan  ) and I want to limit one of the 100Mbps ports to rate limit input to 60Mbps.
What's the best way to do this, and what is the command(s).
Thanks for any help.
5 Replies 5
Ganesh Hariharan
Check out the below link hope this helps out your query
http://www.cisco.com/en/US/docs/ios/12_2/qos/command/reference/qrfcmd8.html
Ganesh.H
Thanks....do you know if there's a similar doc for CatOS??
Or, does anyone know the best command for me to use?
Have a look at this doc and come back if you have further questions -
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/configuration/guide/qos.html#wp1021642
Jon
Thanks Jon....
I think the policer config I need is  :-
set qos policer aggregate WSUS_SERVER rate 51200 burst 61440 drop
However, It's not clear from the document how I apply this to the port??
Any advice greatfully received..
BlueyVIII wrote:
Thanks Jon....
You need to use the policer together with an acl, here is an example -
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801c8c4b.shtml#catos
Jon
