SSL VPN portal doesn´t show URLs.
Dec 19th, 2009
Hi all,
Im interested in SSL VPN which is possible to configure in Cisco 2800 router. So Iv started.
Iv created new web with the URLs pinned to this web, authentication, and so on. Great.
But after the configuration and after Iv loged in to this web I didn´t see URLs Iv created. Its quite strange behavior.
Any idea? Any solution?
Paul Carco Thu, 12/31/2009 - 12:19
Sounds like a possible DNS issue.   Have you configured 'dns-server' and 'ip domain name'  ?
gabrielgr Sun, 01/03/2010 - 03:13
Hi, Iv found the reason. Iv configured SSL VPN from GUI and didnt check config in router and inside VPN profile was command which masks
URLs. With "no" key it shows the URLs.
locus2007 Wed, 03/31/2010 - 11:42
Hallo, now I got same problem as you but con't get it work.
Please what did you exactly done?
have there
url-list "URList"
   heading "Favorites"
   url-text "OWA" url-value "http://192.168.x.x/owa/"
and then
policy group policy_1
   url-list "URList"
That all I thing is for URL lists to show
