sending calls from a certain number to queue
Answered Question
Dec 19th, 2009
I have agents in London and in the US. Termporarily I want the London contact center calls from XXX to go to only 3 of my 12 agents. Is here a way for the script to see a certain number? Basically I just need to how the script would see calls and send them to a routine.
thanks.
Correct Answer by Marwan ALshawi about 7 years 7 months ago
as mentioned in the above post
you can create another CSQ and assign diffrent skill set to those agents, or you can make them part of skill group set
then assign them to the new CSQ
by the way you meant by calls number xxx the ( calling number or called number )
any way the idea to do it the same
put get call contact info step and put a variable in the desired field ( calling or called ) then put  if step to  compare the result,  if that variable you created == the xxx number you have then goto--> send the call to the new CSQ if not then send it to normal treatment
good luck
please if helpful Rate
Overall Rating: 5 (2 ratings)
Abdulbaseer Mohammed Sun, 12/20/2009 - 08:02
  • Silver, 250 points or more
IS this UCX or UCCE.  You can modify your script to look for the xxx number and then send those calls to any of your 3 agents.  I would recommend you create a sperate queue or skill these 3 agents and look for that skill while routing.
You may want to use a If statement and when true use the skill or queue selection if not your call will continue as it is today.
Please rate helpful hints.
Correct Answer
Marwan ALshawi Sun, 12/20/2009 - 16:36
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
good luck
