No rapid-pvst on 2950
Answered Question
Dec 19th, 2009
Hi all, first post, and i suppose i better say noob alert, lol, well, kind of, i'm doing my Honours year at uni for Networking and System Support.
Anyway, for my Honours project i'm doing spanning tree enhancements in small LAN's, which i have to do in Opnet (worse luck), but i bought some 3550's just before i started back as i need to practice and to test stuff anyway, but blew my two 2950's so i had to buy two more!!!
Haven't had much time to play about with them because of other subjects (namely Pervasive Grids, horrible subject!), but now i'm doing my interim report, and i'm now starting to get back into configuring switches again.
However (sorry for the long intro), i cant enable rapid-pvst on the 2950's, there's no option, only for pvst. I was under the impression that the switches had to be at least 12.1(13), and mine are 12.1(19) according to a sh ver. Here's some info from one of the swicthes, and if anybody can shed some light on this i'd be most grateful as i need rapid spanning tree for my project.
AL1#sh ver
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(19)EA1c, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 02-Feb-04 23:29 by yenanh
Image text-base: 0x80010000, data-base: 0x8058A000
ROM: Bootstrap program is C2950 boot loader
AL1 uptime is 42 minutes
System image file is "flash:/c2950-i6q4l2-mz.121-19.EA1c.bin"
cisco WS-C2950SX-24 (RC32300) processor (revision J0) with 20808K bytes of memory.
Processor board ID FHK0821Y0T2
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:11:21:1E:48:80
Motherboard assembly number: 73-8135-07
Power supply part number: 34-0965-01
Motherboard serial number: FOC08210RGH
Power supply serial number: DAB08178J15
Model revision number: J0
Motherboard revision number: A0
Model number: WS-C2950SX-24
System serial number: FHK0821Y0T2
Configuration register is 0xF
AL1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
AL1(config)#span mode ?
  pvst  Per-Vlan spanning tree mode
Gary.
Correct Answer by lamav about 7 years 7 months ago
The Cisco Catalyst 2950SX-48-SI, 2950T-48-SI, 2950SX-24, 2950-24 and 2950-12 are standalone, fixed-configuration, managed 10/100 switches providing basic workgroup connectivity for small to medium-sized companies. These wire-speed desktop switches come with Cisco Standard Image software features and offer Cisco IOS® Software functions for basic data, video, and voice services at the edge of the network.
You need the enhanced image feature set.
Correct Answer by Jon Marshall about 7 years 7 months ago
AL1#sh ver
AL1#conf t
Gary.
Gary
You have the Standard Image running and RSTP is not supported on Standard Image until version 12.1(20)EA2 -
2950 Release Notes
12.1(19) does support RSTP but only with the Enhanced Image.
So you either need the EI for your current IOS version or the SI for 12.1(20)EA2 or later.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Sat, 12/19/2009 - 16:24
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
AL1#sh ver
AL1#conf t
Gary.
Gary
2950 Release Notes
Jon
Correct Answer
lamav Sat, 12/19/2009 - 16:29
  • Blue, 1500 points or more
gjohns23caledonian Sat, 12/19/2009 - 17:14
Thanks for the quick replies Jon and lamav.
Ahhhh, i wasn't aware of that. I just assumed with the IOS being 12.1(19) it would have have rapid-pvst on it.
Ah well, back to Ebay, lol, the switches have to run rapid spanning tree as i'm comparing portfast, backbonefast and uplink fast against rstp.
I'll be back though, i always seem to have no end of problems which i normally manage to solve eventually, but there's always the odd few that stump me.
Cheers again,
Gary.
