I NEED YOUR URGENT HELP
Dec 19th, 2009
hello to every body
i have call manager 6 and i have 3800 voice gateway
recently i bought vosky and i connect it to my fxo ports
i can place calls successfuly but i cannot recieve incoming calls
here is my run config
terface GigabitEthernet0/0
ip address 10.0.110.19 255.255.255.0
duplex full
speed 1000
media-type rj45
h323-gateway voip bind srcaddr 10.0.110.19
interface GigabitEthernet0/1
description $ES_LAN$
no ip address
shutdown
duplex auto
speed auto
media-type rj45
ip route 0.0.0.0 0.0.0.0 10.0.110.254
ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
supervisory disconnect dualtone mid-call
no battery-reversal
input gain 8
output attenuation 1
cptone BE
timeouts call-disconnect 5
timeouts ringing 5
timeouts wait-release 5
timing hookflash-out 500
connection plar opx 1000
impedance complex2
description Line1#2008499
caller-id alerting dsp-pre-allocate
voice-port 0/1/1
no battery-reversal
input gain 8
cptone BE
timeouts ringing 5
impedance complex2
description Line1#2008505
voice-port 0/1/2
no battery-reversal
input gain 8
cptone BE
timeouts ringing 5
impedance complex2
description Line1#2008204
voice-port 0/1/3
no battery-reversal
input gain 8
cptone BE
timeouts ringing 5
impedance complex2
description Line1#2008511
voice-port 0/2/0
no battery-reversal
input gain 8
cptone BE
timeouts ringing 5
connection plar opx 9927
impedance complex2
description Line1#2008515
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
dial-peer voice 1 voip
translation-profile outgoing PSTN-02
destination-pattern 99..
voice-class codec 1
session target ipv4:10.0.110.10
dtmf-relay rtp-nte h245-alphanumeric
no vad
dial-peer voice 10 pots
destination-pattern .T
port 0/1/0
forward-digits all
dial-peer voice 11 pots
port 0/1/1
forward-digits all
dial-peer voice 12 pots
port 0/1/2
forward-digits all
dial-peer voice 13 pots
port 0/1/3
forward-digits all
dial-peer voice 14 pots
shutdown
port 0/2/0
forward-digits all
dial-peer voice 2 voip
preference 1
destination-pattern 1000
voice-class codec 1
no vad
gateway
timer receive-rtp 1200
telephony-service
max-conferences 12 gain -6
transfer-system full-consult
1000 is my auto attendant
any help will be appreciated
halhegelan Fri, 12/25/2009 - 21:37
hi
thank you for your reply
translation profile 2 is for auto attendant
i would like calls to be answered by auto attendant
i hope it is clear
nother thing if i put any extension rather than auto attendant ,it is ringing
but it is a very strange ring
it rings and when you pick up a phone it is having dial tone it means you can dial
and beside dial tone it keeps ringing but with diffrent intervals
what i mean is sometimes a ring after 2 seconds then again after 5 seconds then again after 1 second
i hope this is clear
thankx in advance
Marwan ALshawi Sat, 12/26/2009 - 17:57
Hi Hisham
try to make a trunk group aggregating all your FXO ports
for example
trunk group VOSKY
voice port x/x/x   -- fxo
trunk-group VOSKY
do the same under all of the fox ports
create one dial peer
dial-peer voice 99 pots
destination-pattren .T
forward digits all
and then do some debuging to your calls make sure the call sent through your ports using the right dial peer also check the singling as well
good luck
if helpful Rate
halhegelan Sun, 12/27/2009 - 01:06
thank you marwan shawi for your answer
i try what you mentioned with no success
halhegelan Sun, 12/27/2009 - 04:46
thank you again for your reply
but i donnot have issuefor out bound calls
my issue with in bound calls
i can issue calls with out any issue
but i cannot recieve calls although calls are hitting my gateway
Marwan ALshawi Sun, 12/27/2009 - 17:07
can you do  debug voip dialpeer
then make inbound call  and post the output here
halhegelan Sun, 12/27/2009 - 21:47
Thank you again Marwan
here is the out put of my debug
*Dec 28 05:51:47.172: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x65FF807C,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=10
*Dec 28 05:51:47.172: //-1/EB7ADB9380B3/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1000, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1000
   Result=Success(0) after DP_MATCH_DEST
*Dec 28 05:51:47.172: //-1/EB7ADB9380B3/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=2
     2: Dial-peer Tag=12
     3: Dial-peer Tag=10
     4: Dial-peer Tag=13
     5: Dial-peer Tag=11
*Dec 28 05:51:50.172: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Dec 28 05:51:50.172: //-1/ED449F1380B8/DPM/dpMatchPeersCore:
*Dec 28 05:51:50.172: //-1/ED449F1380B8/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
     2: Dial-peer Tag=13
     3: Dial-peer Tag=10
     4: Dial-peer Tag=12
     5: Dial-peer Tag=11
*Dec 28 05:51:53.172: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Dec 28 05:51:53.172: //-1/EF0E629380BD/DPM/dpMatchPeersCore:
*Dec 28 05:51:53.172: //-1/EF0E629380BD/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
     2: Dial-peer Tag=12
     3: Dial-peer Tag=13
     4: Dial-peer Tag=10
     5: Dial-peer Tag=11
*Dec 28 05:51:56.172: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Dec 28 05:51:56.172: //-1/F0D8261380C2/DPM/dpMatchPeersCore:
*Dec 28 05:51:56.172: //-1/F0D8261380C2/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
     2: Dial-peer Tag=11
     3: Dial-peer Tag=12
     4: Dial-peer Tag=10
     5: Dial-peer Tag=13
*Dec 28 05:51:59.168: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Dec 28 05:51:59.172: //-1/F2A1E99380C7/DPM/dpMatchPeersCore:
*Dec 28 05:51:59.172: //-1/F2A1E99380C7/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
     2: Dial-peer Tag=11
     3: Dial-peer Tag=10
     4: Dial-peer Tag=13
     5: Dial-peer Tag=12
*Dec 28 05:52:02.168: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Dec 28 05:52:02.172: //-1/F46BAD1380CC/DPM/dpMatchPeersCore:
*Dec 28 05:52:02.172: //-1/F46BAD1380CC/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
     2: Dial-peer Tag=11
     3: Dial-peer Tag=13
     4: Dial-peer Tag=10
     5: Dial-peer Tag=12
Marwan ALshawi Mon, 12/28/2009 - 17:10
from the above output the call matching dialpeer 2
my question is are using auto attendant ?
is in unity, ccx or what ? and what codec you are using ?
try to add this command under the dialpeer 2 instead of the codec calss
if you use in in your ivr or AA cdec as g711ulaw
under dialpeer 2 add :
codec g711ulaw
also make sure that your translation is configured correctly
halhegelan Tue, 12/29/2009 - 05:23
thank you again
already i have g711ulaw
iam using exchange 2007 as auto attendant
translation is configured proerly and it is working properly with E1 lines
