Question About MDS heart beat
david.macias Tue, 12/22/2009 - 05:44
Are you sure you're only seeing this during high call volumes?  Do you have a private network between your roggers?  If you do, are you using QoS for the MDS packets?  I would certainly try and resolve this issues ASAP as a loss of 5 consecutive MDS messages will result in the system to go into symplex, which depending on your PG setup might not be a problem.
