OSPF and EIGRP hello on serial link
Answered Question
Dec 20th, 2009
When OSPF is enabled on serial point-to-point link how hellos are sent to other end router? Are hello packets are sent as multicasts?
If yes what is the IP address as destination and source ( source - most likely IP address of serial interface )
To form a neighbor relationship intial hellos are to be received from neighbor and periodic hellos are requred to sustain the already formed
adjacency.  What are the IP address of the hellos after adjacency is established or is it the same? Is it so that once adjacency is established hellos are sent as unicast to other end of router?
In short
Case 1. OSPF  Hello packet - source IP and Destination IP while adjacency is getting established ?
Case 2. OSPF Hello packet - soiurce IP and Destination IP after adjacency is established?
On similar lines how hellos are sent in EIGRP case?
Please share the experience.
Subodh
Correct Answer by paolo bevilacqua about 7 years 5 months ago
Hellos are always multicast unless you configure an explicit neighbor.
All this is explained in the documentation that I recommend you to read.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Sun, 12/20/2009 - 06:13
  • Hall of Fame,
    Founding Member
vinodsharma7 Sun, 12/20/2009 - 12:23
hello,
Ospf destination address for all routers: 224.0.0.5
ospf destination address for DR/BDR: 224.0.0.5
Eigrp multicast address : 224.0.0.10
thanks
vinod
paolo bevilacqua Sun, 12/20/2009 - 12:38
  • Hall of Fame,
    Founding Member
small typo, ospf dr is 224.0.0.6
Muhammad Anser Khan Mon, 12/21/2009 - 02:07
Dear Subodh,
You can also see the multicast packets by the following debug commands:
#debug ip packet detail
#debug ip ospf hello
Anser
Muhammad Anser Khan Mon, 12/21/2009 - 02:09
Dear Subodh,
Anser
