Catalyst3750-E Object Tracking
Answered Question
Dec 20th, 2009
  • Gold, 750 points or more
Hello all,
I have Catalyst 3750-E and need to use the object tracking.
When I configure the object tracking on the Cat3750-E, I found the message as below
saying "% Attempting to exceeded list size limit"
Switch(config)#track 200 list boolean and
Switch(config-track)#object 1
Switch(config-track)#object 2
Switch(config-track)#object 3
Switch(config-track)#object 4
Switch(config-track)#object 5
Switch(config-track)#object 6
Switch(config-track)#object 7
Switch(config-track)#object 8
Switch(config-track)#object 9
Switch(config-track)#object 10
Switch(config-track)#object 11
Switch(config-track)#object 12
Switch(config-track)#object 13
Switch(config-track)#object 14
Switch(config-track)#object 15
Switch(config-track)#object 16
Switch(config-track)#object 17
I think that it support maximum number is 16.
Is this the feature??
If so,are there any reference to it in any of the docs?
When I use IOS 12.2(50) and (53)SE , I found the problem.
IOS description.
c3750e-universal-mz.122-50.SE ipservices
c3750e-universal-mz.122-53.SE ipservices
Best Regards,
Tomoyuki
Correct Answer by Giuseppe Larosa about 7 years 4 months ago
Hello Tomoyuki,
the single object index can be any number between 1 and 500. However you are building a track list by putting in AND N simple objects.
So it is reasonable to have a limit of 16.
It means 16 different conditions you can take in account.
You should be able to configure multiple track lists with a different track index (again between 1 and 500) or  to define and use other objects standalone.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750e_3560e/software/release/12.2_50_se/configuration/guide/sweot.html#wp1078760
in your case having used the AND operator the list is up only if each of the objects is up and it is down if one or more objects are down.
I tried to look in command reference of 12.2(50)SE and in command references of 12.4 mainline but I couldn't find a description of track xx list command.
The config guide describes the command but it doesn't say the maximum number of objects that can be in a track list.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Mon, 12/21/2009 - 00:32
  • Hall of Fame,
    Founding Member
Hello Tomoyuki,
see
Hope to help
Giuseppe
t-yamashita Mon, 12/21/2009 - 00:46
Hello Giuseppe
Thank you for your quick response.
I'm grateful to you.
Tomoyuki
