CSS Licensing
FernandoSP
I want to configure an Active/Active configuration between two different CPD's with Cisco CSS11503. I have readen, that for make this configuration, I need the S11K-500EN-8.2= license, but I don't know how to check if my devices are licensed this way. I've tried "sh version" command, but results are not what I was awaitng for (not like a Cisco ASA f.ex.)
Please, could you say me how can I check my CSS's active license?
Thanks and regards.
I'm sorry Fernando, I didn't have a CSS in front of me when I mentioned 'sh chassis'. 'Show version' will display the licenses currently associated with the device:
CSS# show version
Version:               sg0810205 (08.10.2.05)
Flash (Locked):        08.10.1.06
Flash (Operational):   08.10.2.05
Type:                  PRIMARY
Licensed Cmd Set(s):   Standard Feature Set
                       Secure Management
S11K-500EN-8.2 == Enhanced Feature Set. If you do a 'sh ver' and see the Enhanced Feature Set as one of the licensed command sets, you should be good.
James
busterswt
The results from 'show chassis' should display what you need to know.
- James
Hi James,
I executed sh chassis command, but I think I don't get the info I wished.
I get S/N, product name (CSS11503-AC L0) and sw version (08.20.0.01), but I think it's not the info I need.
Any other idea? I'm absolutelly lost about CSS licensing.
Thanks.
CSS# show version
Type:                  PRIMARY
                       Secure Management
James
Hi James,
Thanks a lot.
