12-21-2009 05:56 AM
Ip phone on remote site can not register on CUCS. VPN is up, pings are ok, I can ping from remote voice subnet to the local CUCS subnet. However, when IP phone tries to register with CUCS, I get the following:
%ASA-6-302015: Built outbound UDP connection 68507 for vpn-baku:192.168.128.10/69 (192.168.128.10/69) to astara_data:192.168.140.5/49152 (192.168.140.5/49152)
%ASA-6-302015: Built outbound UDP connection 68508 for vpn-baku:192.168.128.10/34488 (192.168.128.10/34488) to astara_data:192.168.140.5/49152 (192.168.140.5/49152)
%ASA-6-110003: Routing failed to locate next hop for UDP from vpn-baku:192.168.128.10/34488 to astara_data:192.168.140.5/49152
Local ASA:
ASA Version 7.0(8)
hostname azt-bridge-asa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
dns-guard
interface GigabitEthernet0/0
nameif azt-inside
security-level 100
no ip address
interface GigabitEthernet0/0.32
vlan 32
nameif azt_data
security-level 100
ip address 192.168.32.9 255.255.255.0
interface GigabitEthernet0/0.129
vlan 129
nameif azt_voice
security-level 100
ip address 192.168.128.9 255.255.255.0
interface GigabitEthernet0/1
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
nameif baku-outside
security-level 0
ip address 10.253.17.1 255.255.255.0
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
same-security-traffic permit inter-interface
access-list 110 extended permit ip 192.168.32.0 255.255.255.0 any log
access-list 110 extended permit ip 192.168.128.0 255.255.255.0 any log
access-list 110 extended permit ip 10.253.17.0 255.255.255.0 any log
access-list 110 extended permit ip any any log
access-list nonat extended permit ip 192.168.128.0 255.255.255.0 192.168.140.0 255.255.255.0
access-list nonat extended permit ip 192.168.32.0 255.255.255.0 192.168.86.0 255.255.255.0
pager lines 24
logging monitor debugging
logging asdm informational
mtu azt-inside 1500
mtu azt_data 1500
mtu azt_voice 1500
mtu baku-outside 1500
mtu management 1500
no failover
asdm image disk0:/asdm-508.bin
no asdm history enable
arp timeout 14400
nat (azt_data) 0 access-list nonat
route baku-outside 192.168.140.0 255.255.255.0 10.253.17.2 1
route baku-outside 0.0.0.0 0.0.0.0 10.253.17.2 1
route baku-outside 192.168.86.0 255.255.255.0 10.253.17.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
username admin password fOxbBT5HEEz5OxJT encrypted
aaa authentication ssh console LOCAL
aaa authentication enable console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map bakumap 10 set security-association lifetime seconds 28800
crypto map bakumap 10 set security-association lifetime kilobytes 4608000
crypto map mymap 20 match address 110
crypto map mymap 20 set peer 10.253.17.2
crypto map mymap 20 set transform-set myset
crypto map mymap 20 set security-association lifetime seconds 28800
crypto map mymap 20 set security-association lifetime kilobytes 4608000
crypto map mymap interface baku-outside
isakmp enable baku-outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
tunnel-group 10.253.17.2 type ipsec-l2l
tunnel-group 10.253.17.2 ipsec-attributes
pre-shared-key *
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 azt_data
ssh timeout 30
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd enable management
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect skinny
inspect tftp
service-policy global_policy global
Cryptochecksum:1e9b30c67a892c2a5111102814efa994
: end
Remote ASA:
ASA Version 7.0(8)
hostname azt-astara-asa
enable password zk4oxIHVgmgitTUn encrypted
passwd XeY1QWHKPK75Y48j encrypted
names
dns-guard
interface Ethernet0/0
speed 100
duplex full
nameif astara_inside
security-level 100
no ip address
interface Ethernet0/0.86
vlan 86
nameif astara_data
security-level 100
ip address 192.168.86.1 255.255.255.0
interface Ethernet0/0.140
vlan 140
nameif astara_voice
security-level 100
ip address 192.168.140.1 255.255.255.0
interface Ethernet0/1
shutdown
no nameif
security-level 100
no ip address
interface Ethernet0/2
nameif vpn-baku
security-level 0
ip address 10.253.17.2 255.255.255.0
nameif management
security-level 100
management-only
ftp mode passive
access-list nonat extended permit ip 192.168.86.0 255.255.255.0 192.168.32.0 255.255.255.0
access-list nonat extended permit ip 192.168.140.0 255.255.255.0 192.168.128.0 255.255.255.0
access-list 120 extended permit ip 192.168.86.0 255.255.255.0 any log
access-list 120 extended permit ip 192.168.140.0 255.255.255.0 any log
access-list 120 extended permit ip 10.253.17.0 255.255.255.0 any log
access-list 120 extended permit ip any any log
pager lines 24
mtu astara_inside 1434
mtu astara_data 1434
mtu astara_voice 1434
mtu vpn-baku 1434
mtu management 1434
arp timeout 14400
nat (astara_data) 0 access-list nonat
route vpn-baku 0.0.0.0 0.0.0.0 10.253.17.1 1
route vpn-baku 192.168.32.0 255.255.255.0 10.253.17.1 1
route vpn-baku 192.168.128.0 255.255.255.0 10.253.17.1 1
http server enable
crypto map mymap 10 set security-association lifetime seconds 28800
crypto map mymap 10 set security-association lifetime kilobytes 4608000
crypto map mymap 20 match address 120
crypto map mymap 20 set peer 10.253.17.1
crypto map mymap interface vpn-baku
crypto map bakumap 20 set security-association lifetime seconds 28800
crypto map bakumap 20 set security-association lifetime kilobytes 4608000
isakmp enable vpn-baku
tunnel-group 10.253.17.1 type ipsec-l2l
tunnel-group 10.253.17.1 ipsec-attributes
pre-shared-key *
telnet 0.0.0.0 0.0.0.0 astara_inside
telnet 0.0.0.0 0.0.0.0 vpn-baku
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 astara_inside
ssh 0.0.0.0 0.0.0.0 astara_data
ssh 0.0.0.0 0.0.0.0 vpn-baku
ssh timeout 30
console timeout 0
dhcpd lease 3600
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect skinny
inspect tftp
Cryptochecksum:098102765abe4083a2747930e3d4a1bb
: end
azt-astara-asa#
Basically, I can ping from 192.168.140.0 (remote voice) to 192.168.128.10 (local CUCS) and vice versa.
Thank you in advance
12-21-2009 09:19 AM
First of all, I'll suggest you to re-configure your crypto maps ACLs, even though the tunnel is establishing, the best practice is to have them configured as in a mirror.
As far as I understand your configuration you just want to communicate the data VLAN in the Local site with the data VLAN from the remote site. So your ACLs should look like this:
Local ASA:
access-list 110 extended permit ip 192.168.128.0 255.255.255.0 192.168.140.0 255.255.255.0
access-list 110 extended permit ip 192.168.32.0 255.255.255.0 192.168.86.0 255.255.255.0
Remote ASA:
access-list 120 extended permit ip 192.168.86.0 255.255.255.0 192.168.32.0 255.255.255.0
access-list 120 extended permit ip 192.168.140.0 255.255.255.0 192.168.128.0 255.255.255.0
*Note: Try to avoid having permit ip any any in crypto Map ACL
Also add the nonat ACLs you alread have created to the interfaces with voice traffic.
Local ASA:
nat (azt_voice) 0 access-list nonat
Remote ASA:
nat (astara_voice) 0 access-list nonat
That should work for you.Cheers!
- Yamil
12-22-2009 12:54 AM
Issue is solved, I removed interface GigabitEthernet0/0.129 from ASA, left only interface GigabitEthernet0/0.32 and used it as a default gateway.
