Configuring two gateways peers on a ASA 5540
Dec 21st, 2009
There is a requirement to configure 2 gateway peers for a single tunnel. I dont see any command after "set peer" that would actually allow us to create a second peer for the tunnel. Is there a way to do this. Or if I give the command "crypto-map outside 10 set peer" the second time, will it create an additional peer for the tunnel
acomiskey Mon, 12/21/2009 - 07:28
  • Green, 3000 points or more
You can put them both in the same statement.
crypto map outside 10 set peer x.x.x.x y.y.y.y
