12-21-2009 07:36 AM
Normally when I run the device discovery service, I can see the statistics in Device Discovery Summary and its take at least an hour.
Now when I hit the Discovery button, CW says it has completed the job -in less than 5 seconds. The Device STatus says its "Stopping. PLease refresh the page to get the status". When I refresh the page, the status says it "Completed"
Discovery Status: | Stopping. Please refresh the page to get the status |
Discovery Start Time: | Mon Dec 21 23:33:01 |
Discovery End Time: | |
Total Devices Discovered: | 0 |
Reachable Devices: | 0 |
Unreachable Devices: | 0 |
Devices Newly Added to DCR: | 0 |
Devices Updated to DCR: | 0 |
I dont think CW discovery is working, how can i resolve the issue?
Thanks in advance,
12-21-2009 07:39 AM
Post the CSDiscovery.log and NMSROOT/conf/csdiscovery/CSDiscovery-config.xml file. What version of Common Services is this?
12-21-2009 07:54 AM
Hi Clark,
Youre a God send!. Thanks for your help.
Im running version 3.3.0
12-21-2009 07:55 AM
You didn't post the CSDiscovery.log.
12-21-2009 08:03 AM
Apology..Please see attachedment
12-21-2009 08:08 AM
I think the discovery got corrupted when I restart xmldb. There was a post where you ask me to reinitialize the opsxml database.
see attachment
12-21-2009 08:09 AM
I don't see any errors here. You've blocked out a lot of the configuration, so I can't say for certain, but it looks like your settings might be too restrictive. You only have the CDP module enabled with one seed device, and without jump router boundaries. While you do have DCR devices enabled for seeds, it's not clear how the filters apply. I recommend you open a TAC service request so the actual file contents can be checked along with the ngdiscovery.log with appropriate debugging enabled.
12-21-2009 08:25 AM
I think I identify the problem. I added/included the filters for the devices. I exclude the filters IPs and its rediscovering. phewsss
You only have the CDP module enabled with one seed device, << How many seed device should I add? If I have 5 branches, is that mean I have to add 5 devices? I though once cw will look at the cdp table, collect the data then it go onto another device and repat the process. ???
12-21-2009 08:28 AM
There are no hard and fast rules. I just commented that your Discovery settings may have been too weak. If, after you fixed the filters, Discovery is working, then one seed may be enough. In general, you need to add one CDP seed for each CDP domain (i.e. each area where CDP is properly advertised). If you use technologies like MPLS where CDP does not work, you would need to add one CDP seed per MPLS-connected campus in order for Discovery to find everything.
12-21-2009 08:36 AM
Thanks for the feedback.
How can you find out which device has CDP seed enable for each CDP domain? I got cdp enable for all of my devices.
Back to the problem, the reason CS stopped discovering because of the filter. I want to added/filter out the ip addresses so next time when I run discovery again, CW will ignore those ip addresses. obviously it didnt work. Any idea why the filter didnt work? I INCLUDED the devices in the filter.
12-21-2009 08:43 AM
You can use the "show cdp neighbor" command on each device to verify CDP is properly advertised everywhere. You may also want to enable Jump Router Boundaries. If you do not, you will need to add a CDP seed for each routed subnet.
Without knowing exactly what the IP addresses you used for filtering, and what IP addresses are configured on the devices in DCR, I cannot say for certain why the filters were not working. I can say that when you use include filters, Discovery checks the devices to see if they have an IP address which matches the filter. If the devices are in DCR with a management IP address, then pre-filtering will be done on that address, and only devices which match the include filter will be processed.
12-21-2009 08:51 AM
That's what I though the filter would do, but it didnt.
So how do I setup CW and tell it to collect only 1 ip address for each device?
My system went out there and it collect all the IP addresses on the same device, that's why I use the filter.
12-21-2009 10:21 AM
The filters are only pre-applied to seed devices. For discovered devices, Discovery will walk the ipAddrTable of those devices to get all of the configured IP addresses. This is not configurable.
12-21-2009 08:10 AM
No, the OpsXML database has no bearing on Discovery. CWA is completely separate from CS Discovery.
12-21-2009 08:16 AM
What's all that initialize the log4j system warning messages in CSDiscovery.log?
There's alot of errors, in csdiscovery.log file
