ASA 5500 Access List removal
Answered Question
Dec 21st, 2009
I do apologise for reposting; however I am still having a few issues.
After removing a capture from the firewall, I am now trying to remove the access-list associated.
However, the below output shows that the access-list is still infact present on the firewall
host# sh access-list SL-CAP
access-list SL-CAP; 0 elements
host# conf t
host(config)# clear configure access-list SL-CAP
host(config)# wr
Building configuration...
[OK]
host(config)# end
host# sh run | inc SL-CAP
#no output#
Although it is not really a big problem; it would be nice to resolve and see what is causing this strange behaviour.
Correct Answer by Kureli Sankar about 7 years 4 months ago
If the following doesn't work
conf t
clear config access-list SL-CAP
Then add a few lines of dummy acl to the access-list like
access-l SL-CAP permit icmp any any
access-l SL-CAP deny ip any any
Make sure sh access-l SL-CAP | i elements
shows 2 and then try the same thing again.
clear config access-l SL-CAP
-KS
Overall Rating: 5 (1 ratings)
Dale Sanderson Mon, 12/21/2009 - 08:31
I believe that using "no" will only remove particular ACL entries as opposed to the ACL itself; forgive me if I am wrong on that..
No, infact you are right, thanks for making me rush to the config guide ,  but at times there are few commands that need system restart to flush out from the NVRAM. Not sure about this particular command. I haven't used the clear configure command, rather i usually copy the config to a notepad and add a no statement to the ACL (to all if i need to delete the complete ACL).
Dale Sanderson Mon, 12/21/2009 - 09:11
Ok, thankyou for the advice!
I will leave this thread open for a little to see if further networking guru's can advise & at a last resort I will use your method.
Thanks again!
Correct Answer
Kureli Sankar Mon, 12/21/2009 - 09:13
  • Cisco Employee,
conf t
-KS
Dale Sanderson Mon, 12/21/2009 - 09:21
You my friend, are a star!
That worked perfectly - I take it that an 'empty' access list cannot be removed and will bare this in mind for future and ensure the list is populated.
Thanks again!
Related Content
