shetting up SSH in Cat 2950 switch
Dec 21st, 2009
I am trying to configure SSH on the Cat 2950 switch.  AAA needs to be configured for authentication using the local database.  What does the following sentence mean? "When configuring the local authentication and authorization authentication method, make sure that AAA is disabled on the console".
Ganesh Hariharan Sat, 12/26/2009 - 08:06
For configuring ssh  in switches you should have cryptography images with switches it will be in names like K9 in ios name and configuraing aaa check ou the below link hope this helps out your query !!
The message genrally indicates to avoid for packet to move to radius/tacas that login can happen via local database.
