SPA509G & BLF & Asterisk
Dec 21st, 2009
It's possible to configura a line key 1 with an extended function like
fnc=blf+sd+cp;[email protected];nme=Ext 200
in order to monitor the extension 200 without an attendant Console?
I did it on an spa942 and spa962 but i don't know if it's possible on a SPA5XX
Thanks in advance
cinglalls Mon, 12/21/2009 - 10:54
I try it, but the led is all the time orange.
My Configuration is:
Extension: Disabled
Share Call Appearance: Shared
Extended Function: fnc=blf+sd+cp;[email protected];nme=Ext 200
Short Name: 200
Server Type: Asterisk
The Call Pickup and BLF doesn't work Speed Dial Works fine
Can you help me?
Patrick Born Mon, 12/21/2009 - 15:12
Hi cinglalls,
At asterisk's CLI, type: core show hints
This will tell you who is watching what
Verify that you've a hint in the extensions.conf file.
Example:
SPA509 has the following configuration to subscribe and monitor extension 508:
     fnc=blf+sd+cp;[email protected];nme=508
The extensions.conf has the following:
exten => 508,1,Dial(SIP/508,10,rT) ;ring for 10 seconds
exten => 508,hint,SIP/508 ; hint: core show hints *CLI sees extension state
exten => 508,2,VoiceMail([email protected],u)
exten => 508,3,hangup
exten => 9508,1,VoiceMailMain(508) ;mailbox access for extension
Make sure that the sip.conf allows your phone to subscribe to extension 200's state. Continuing my example, sip.conf snippet:
; allow phone to subscribe to another phone's extension state
allowsubscribe=yes
notifyringing=yes
limitonpeer=yes
notifyhold=yes
Patrick
cinglalls Mon, 01/04/2010 - 09:57
I put the other unused extensions to disabled and it works.
Thank's for your help.
adpslabcisco Thu, 03/04/2010 - 04:39
I have a SPA504G and I'm trying to configure BLF with Elastix 1.6.
I can make a speed dial but the ligth is off.
Ryan Finnie Thu, 08/12/2010 - 11:24
FYI, I had the same type of problem (getting the last 4 line keys to be BLF+SD on a SPA509G), and disabling the unused lines did not help.  It turned out the attendant console units were enabled in the config, but I did not have any SPA500S units attached.  Disabling the two consoles in the config made BLF on the line keys work again.
Related Content
