Cisco 851W - PPPOE
Dec 21st, 2009
I'm trying to setup my Cisco 851W to connect to my DSL Modem with a PPPOE connection.
I tried using the SDM Internet (WAN) option and enabled the PPPOE option with a Dynamic IP Address with both Chap & PAP, but cannot get access to the Internet.
If I try to set it up with a Dlink Router, I have no problem getting to the Internet.
Is there a way to monitor the connection to my PPPOE account with the Cisco 851w?  I don't see any errors under "show log"
Do anyone know of a good document on how to setup PPPOE with the Cisco 851w?
Thanks in Advance
conmurph Mon, 12/21/2009 - 17:43
  • Cisco Employee,
Dale Leibel Fri, 08/16/2013 - 04:00
I'm having the same issue with an 851W.  No problem connecting using a Linksys WRT54GV2.  I have attached my configuration and the debug ppp nego logs below...
Here is my configuration:
nterface FastEthernet4
description $ES_WAN$$ETH-WAN$
no ip address
ip verify unicast reverse-path
ip mask-reply
no ip unreachables
ip directed-broadcast
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
Dialer0
description $FW_OUTSIDE$
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname [email protected]
ppp chap password 7 113F4F2746215E
ppp ipcp dns request
debug ppp nego log entries....
000795: *Apr 14 02:12:05.066: Vi1 CHAP: I CHALLENGE id 200 len 33 from "ERX5"
000796: *Apr 14 02:12:05.070: Vi1 CHAP: Using hostname from interface CHAP
000797: *Apr 14 02:12:05.070: Vi1 CHAP: Using password from interface CHAP
000798: *Apr 14 02:12:05.070: Vi1 CHAP: O RESPONSE id 200 len 35 from "[email protected]"
000799: *Apr 14 02:12:05.310: Vi1 CHAP: I FAILURE id 200 len 18 msg is "Request Denied"
paolo bevilacqua Fri, 08/16/2013 - 04:08
  • Hall of Fame,
    Founding Member
You should open nre threads for new probelsm.
Anyway, your ISP may have a MAC lock, ask them to remove it or leave router off for a night or so.
