ASA - Disable Phase 2 traffic volume rekey
Dec 21st, 2009
  • Bronze, 100 points or more
I'm troubleshooting some issues with a typical L2L VPN using IKE Main Mode w/pre-shared key auth.  I'm using an ASA 5550 w 7.2(3) code.
I'm trying to find a way to disable the phase 2 security association lifetime kilobytes (traffic volume) rekey value.  I know that the ASA will not use this value if it is acting as the responder and the initating device does not include the 'Life Type: Kilobytes' in the Security Association payload, but I'm tyring to find a way to disable this if the ASA is the initiator of the tunnel.
Anyone have any ideas?
As far as I know, this cannot be disabled..
Overall Rating: 5 (1 ratings)
busterswt Mon, 12/21/2009 - 19:38
Hey Patrick,
I don't think you can completely disable it, but you can sure set it really high on a per-tunnel basis:
cisco(config)# crypto map rackmap 200 set security-association lifetime kilobytes ?
configure mode commands/options:
  <10-2147483647>  Security association duration in kilobytes (max 2,048 Gigabytes)
Keep it real bro!
James
