Problem with changing "CDR UNC Path" CCM4.1
Dec 21st, 2009
Hello
I need to move "Flat CDR files" from callmanager to my network share server.
After changing Enterprise parameters on publisher server
CDR UNC Path: \\192.168.0.2\CDR\CCM  - this is my share server
Cluster ID* : CCM-Cluster
Local CDR Path* : C:\Program Files\Cisco\CallDetail
I recieved this error:
Error: kErrorNotCDRPrimary - InsertCDR service is being run on a server that is not the CDR primary
  App ID: Cisco CDR Insert
  Cluster ID: CCM-Cluster
  Node ID: CCM  -- this is publisher server
Explanation: InsertCDR service is being run on a server that is not the CDR primary
Recommended Action: Either disable the service or change the Enterprise Parameter for PrimaryCDRUNCPath.
Where I was wrong with configuration?
My CCM version 4.1(3)sr6 (Publisher+1 Subscriber)
"CDR Incert" runs only in Publisher server
