Dec 22nd, 2009
I am new to cisco security. I have problem in ACS 5.0. Can somebody guide me in configuring the ACS or I Really need book that has step by step procedure to adding users ,network device group, policies and access policies...plss
nagabhushana.k Wed, 12/23/2009 - 00:12
Depending on the requirement you can go ahead with configuration. I mean, ACS can be used to grant users access to devices' administration (ex: administration of Routers, Switches etc) and also for Network access (ex. access to network resources).
You can refer to following URLs:
I hope it help you to configure ACS. All the best.
ansalaza Thu, 12/31/2009 - 08:37
These are the links for the general ACS 5.X configuration:
End-User Guides
Install and Upgrade Guides
It would be recommended to read the guide, start working your way up, once you have some issues then let us know so we can try to help you out with what we can...
ericohermoso Wed, 02/03/2010 - 22:43
thanks guys, from the sites that you have given i started the acs configuration, that works fine. But whenever i use enable i got an error message like Authentication failed.
My configuration goes like this
aaa new-model
aaa authentication login telnet_lines group tacacs+
aaa authentication enable default group tacacs+ enable----------when i use this command i got AUTHENTICATION FAILED
enable password cisco
aaa session-id common
tacacs-server host key cisco
line vty 0 4
authorization commands 15 telnet_lines
authorization exec telnet_lines
login authentication telnet_lines
guys, I am using ACS 5.0. What should i do with this?
