12-22-2009 02:45 AM - edited 03-15-2019 08:51 PM
Dear all
I have cisco callmanager 7.0 and some third part sip phones
my cisco ip phones can make call to my third part sip phones visa versa
but the point is my cisco ip phones can call outside but i can not make outside call with my sip phones
please guide me
12-22-2009 04:50 AM
first check the sip phone CSS
for testing mae sure the sip phne and line CSSs same as the cisco ip phone as you mentioned the cisco one can make call out
next what type of voice gateways you are using ?
i will assume you are using h323
if this si the case debuge voip dialpeer
and make a call from the sip phone just to see the call reaching the gateway or not
if you see result that means the call reaching the gateway if nothing that mean your issue still in callmanger side
after that try to assine MTP resources to the GW MRGL and reset the gateway from call maager
good luck
if helpful Rate
12-22-2009 05:42 AM
Thank you for your response
about CSS its ok .
my cisco 2811 is my voice gateway and my i have E1 for PSTN and the voice gateway signaling is h323
about the dialpeer debug i should say that we do not recive anythig from callmanager
