ebgp Connection with PIM but no MP-BGP Configuration
Answered Question
Dec 22nd, 2009
Hi All,
Quick one if I may.
If you run eBGP with an external AS and you want to pass multicast over from one AS to another (lets say both ASs are within my admin control), can I just run PIM on the interfaces on both ends of the eBGP connection (lets say they are directly attached) and multicast will flow through?
Or do I have to configure MP-BGP?
Many thx indeed,
Ken
Correct Answer by Nagendra Kumar ... about 7 years 4 months ago
If your AS is already aware of the Multicast source addresses, you can have MSDP between AS and have the traffic flow between AS. But incase, you dont have or dont need unicast traffic between sources in different AS, you need MP-BGP with multicast AFI and advertise the source prefix.
This will be only used for RPF and not for unicast traffic forwarding.
HTH,
Nagendra
Correct Answer by Marwan ALshawi about 7 years 4 months ago
of course you can
MP-BGP not required at all
you need MP-BGP if you have MPLS network
by the way if you want to enable bgp between tow BGP domains in diffrent AS you may need to consider MSDP for better control and security
have a look at the following document:
https://supportforums.cisco.com/docs/DOC-8293
good lcuk
if helpful rate
Overall Rating: 5 (2 ratings)
Correct Answer
Marwan ALshawi Tue, 12/22/2009 - 04:21
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
of course you can
good lcuk
if helpful rate
Correct Answer
Nagendra Kumar ... Tue, 12/22/2009 - 05:50
  • Cisco Employee,
HTH,
Nagendra
kfarrington Tue, 12/22/2009 - 06:31
Many thx to all of you for the response.  This is great
Kind regards,
Ken
