Creating a autoattendant script
Dec 22nd, 2009
I am customizing design of  default script aa_sample.aef with CUE editor.
Instead of second option "Dial by Name"  i want to direct call to Voicemail of the called extension with voicemail prompt.
when ever i try same the system of Autoattendant fails, i tried using voicemail from palette plane but confused with what to use in parameters (ie. recipint id. sender id, prompt)
kind help me what to do for VM. Also i wanna know more about editor in detail.
Thanx and regards,
