- D-Channel Blocked -
Answered Question
Dec 22nd, 2009
My ISP says the router is 'blocking out the D Channel'
I am using an MGCP gateway backhauling the ISDN to Call Manager - I am seeing 'path code violations'
yet when the telco puts a loop in the line, it tests clear.
They insist is it the CSU (customer service unit - ie the router!)
I am really stumped here... any ideas ??
Bascially I have 'Layer 1 - Deactivated / Shutdown' with multiple path code violations
Correct Answer by vivkalra about 7 years 3 months ago
This is a definately a Telco related problem.
However to rule out any options from your side you can try configuring it with H323
because D channel is backhauled with call manager in case of MGCP to verify that it is not a call manager issue
you try that with h323 and also make sure we are on the latest IOS on the gateway.
Vivek
Overall Rating: 5 (1 ratings)
Correct Answer
vivkalra Sat, 12/26/2009 - 12:44
Vivek
keanej Wed, 12/30/2009 - 01:22
I help test H323 - I ACL blocked all communication to Call Manager - triggering SRST -  and the fault was still there
The Telco eventually admitted the problem yesterday.
Thanks for your help
Paolo Bevilacqua Sat, 12/26/2009 - 17:36
  • Hall of Fame,
    Founding Member
Please send "show controllers T1"
