ACS SE console password reset error
Dec 22nd, 2009
I'm getting the following error during ACS console password recovery process:
Cisco Secure ACS: 4.2.0.124
Appliance Management Software: 4.2.0.124
Appliance Base Image: 4.2.0.107
Status: Appliance is functioning properly
Default administrator account can be reset now.
Press enter to change default administrator account and password
login: Administrator
password:
Enter new password again:
Error: Failed to set password: rc = [997] Overlapped I/O operation is in progres
Can anyone had faced this problem?
Any help and hint will appericiated. Thannka in advance.
Thank You,
Sunil
Ganesh Hariharan Sat, 12/26/2009 - 08:25
Is the LAN port is connected while doing the basic configuration as error says about the
I/O operation is in progress.If yes just remove the cable and boot once again the ACS and then try to reset the password.
Ganesh.H
ansalaza Mon, 12/28/2009 - 07:43
Do you have a working backup of the ACS Configuration that you could restore?
If you still have access to the GUI using the "GUI Admin credentials",
try to take a backup of the database...
It is very likely that you'll need to re-image the ACS Server
in order to reset the "ACS Console credentials".
Using the same DVD/CD to restore the Administrator password:
ACS Appliance Recovery Options
[1] Reset administrator account
[2] Restore hard disk image from CD
[3] Exit and reboot
Enter menu item number: [2]
This will wipe all your configuration and will re-install the OS, which will force you to re-configure some basic settings like IP address, Gateway, DNS Domain and Servers, NTP Servers...
Once you have GUI access, you can restore your ACS database...the console credentials should not be overwritten by the restore...
HTH.
Related Content
