Steven Smith Tue, 12/22/2009 - 10:41
  • Gold, 750 points or more
Can you get a debug ccsip messages?  From the looks of it, it appears the call is going back towards the ITSP.
MEDITELdoc09 Tue, 12/22/2009 - 11:23
HI,
Dec 22 19:21:07.191: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 10.151.1.4:5060;branch=z9hG4bKvjgf8o00fo80ga8c53k0.1
To: "TEST"[email protected]>;cscf
Call-ID: SDiqbd901-12a12575f49df98c5fafe95fb52c3780-v3000i1
CSeq: 468342564 INVITE
Max-Forwards: 5
Content-Length: 161
Contact:
Content-Type: application/sdp
Allow: ACK, BYE, CANCEL, INFO, INVITE, OPTIONS, PRACK, REFER, NOTIFY
Accept: multipart/mixed
Accept: application/media_control+xml
Accept: application/sdp
P-Asserted-Identity:
Privacy: none
P-Charging-Vector: icid-value="4b311bd250958600828079";icid-generated-at=10.43.8.45;ericsson-imt=1;oaid="Casablanca"
Session-Expires: 1800
Min-SE: 600
P-Called-Party-ID: [email protected]>
v=0
o=BroadWorks 6425945 1 IN IP4 10.151.1.4
s=-
c=IN IP4 10.151.1.4
t=0 0
m=audio 25990 RTP/AVP 0 8 18 4 99
a=rtpmap:99 telephone-event/8000
a=ptime:20
Dec 22 19:21:07.203: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
Date: Tue, 22 Dec 2009 19:21:07 GMT
Allow-Events: telephone-event
Content-Length: 0
To: "TEST"[email protected]>;cscf;tag=41F3D0-43F
Server: Cisco-SIPGateway/IOS-12.x
Dec 22 19:21:07.207: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:[email protected]:5060 SIP/2.0
CSeq: 468342564 ACK
Max-Forwards: 5
Content-Length: 0
Thnaks in advance
Steven Smith Tue, 12/22/2009 - 11:27
Your config was cut off.  It doesn't show any of the access-list.  Could you include that as well.
MEDITELdoc09 Tue, 12/22/2009 - 11:32
access-list 1 permit any
access-list 2 permit any
access-list 100 permit ip any any
access-list 101 permit ip any any
access-list 102 permit ip any any
access-list 103 permit ip any any
MEDITELdoc09 Tue, 12/22/2009 - 11:35
and also::
Received:
SIP/2.0 200 OK
Timestamp: 1261510450
To: [email protected]>;tag=SDo2ctd99-99ea3ee50af03f6092c4497f0babef
Call-ID: D0222B7C-EE6711DE-8060D8E9-91CF9CE7
Via: SIP/2.0/UDP 10.150.14.128:5060;branch=z9hG4bK131E1
CSeq: 3 REGISTER
Content-Length: 0
Contact: ;expires=3599
P-Associated-URI: [email protected]>
P-Associated-URI:
C520#show sip-ua register status
Line          peer           expires(sec)  registered   P-Associated-URI
520207100                         20017       1456          yes
Steven Smith Tue, 12/22/2009 - 11:47
Do you get the same problem if you dial 520207101?
Looks like you have a different translation rule for that number.  520207100 has no translation profile.  Do you want that number to go to AA?
Maulik Shah Tue, 12/22/2009 - 11:52
  • Silver, 250 points or more
UC500 does not support call routing based on the TO header in the SIP INVITE if that is what you are looking for - UC500 routes on the Request URI which is compliant to the SIP RFC. Routing on TO header is generally not recommended (the SIPConnect spec also calls this out). Please change the Broadsoft config to match that.
MEDITELdoc09 Tue, 12/22/2009 - 19:25
Hi Shah,
i will send this pb to our NGN team and back to you.
