ISDN calls on a voice gateway
Dec 22nd, 2009
Hi All,
Can anyone tell me how I can monitor the amount of inbound/outbound calls are made out through a 2821 router connected to an ISDN PRI circuit.
We have 2 MGCP gateways in a Route group and all extensions make outbound calls through both on a round robin basis.
What I need is to get some stats on the amount of calls made in/out on the PRI channels in order to determine whether we actually need all 30 channels on both circuits.
Overall Rating: 5 (1 ratings)
Justin Brenton Wed, 12/23/2009 - 10:32
  • Silver, 250 points or more
Hi There,
Show Voice Call Summary will show the status of all voice ports.
These will also help:
show isdn active
Shows ISDN calls in progress
show isdn history
Shows ISDN call history
show isdn status
Shows ISDN line status
Commands to Verify Voice Ports
Command
Description
show voice port
Shows all voice port configurations in detail
show voice port slot/subunit/port
Shows one voice port configuration in detail
show voice port summary
Shows all voice port configurations in brief
show voice busyout
Shows all ports configured as busyout
show voice dsp
Shows status of all DSPs
show controller T1 | E1
Shows the operational status of a controller
HTH, Please rate if so
Justin
