How can I monitor CM 7.1.3 and IP Phones with netmanager 1.1?
Dec 22nd, 2009
I far as I know netmanager 1.1 does not support CM 7.1.3 but I would like to monitor it including IP phones. Currently I can not display any IP phone.
I would like also monitor unity 7.1, Meeting place 2.1.2., Presence 7.0.5
Any idea?
Nael Mohammad Wed, 12/23/2009 - 10:49
As I'm not sure which netManager you have, I've included the supported device table for both Unified Communications and IP Infrastructure 1.1:
Release notes:
From the web interface, click Go > Devices > New Device --> Enter IP address or hostname --> Click OK to add device.  If the device is not supported per the supported device table, it will not populate .  You can file a product enhancement request for updated device support.
filiberto.aguirre Wed, 12/23/2009 - 11:28
Hi Nael,
thanks for your info.
I have netmanager 1.1, the supported CM  version is 7.0(1)   but I have CM 7.1.3.
I guess that's why netmanager can not display CM and phones.
To whom I should address in order to request a product enhacement for updated devices??
