Double-check my QoS config??
Dec 22nd, 2009
Can you guys take a look over my qos config?? It is mostly pseudocode so if commands are not exact that is why. We have Silver-Peak WAN Optimization devices placed inline at each location. We will be peering with the PE router via eBGP. All traffic will be marked downlevel at the access layer and in the core where necessary. Please let me know if you need more information.
Marwan ALshawi Tue, 12/22/2009 - 15:25
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
look fine
but i have some notes
the comma not required in the class map config
you may recieve an error when you put your policymap egress becuase you ned to use one priority method when configuring CBWFQ
i mean you need to use either bandwidth percent  command or bandwidth remaining percent in all of the class within that policy
laso for to make sure your routing traffic is fine
as long as you using the whole interface bandwith with your policy
try to make a class with few garnteed bandwith for cs 6 and cs 7 instead of having it under best effort
good luck
if helpful Rate
