ACS 4.2 How to unlock the account every 30 mins
Dec 22nd, 2009
I set the Account Disable->Failed attempts exceed:5
when users type wrong password 5 times ,the account was locked by system.
When the accounts were locked,I must be login ACS server and unlock users account.
If I don't want to unlock ths accounts,the system have the solution like every 30 mins to unlock the accounts automaticity?
and how to assign?
THS
gshinman Tue, 12/29/2009 - 03:57
I assume you are reffering to a local user database on ACS. If you're talking about a single, stand alone, ACS then I don't believe that is possible within the GUI. If you have a number of ACS's and a master replication server (like I do) then your job is easier. The master replication server can replicate the user database and if the user stays enabled on the master servers then he/she is reenabled every time there is a replication to the other servers. If the user is locked on the master then they will also be locked out everywhere else after a replication.
If this is a standalone server then the only way to do this is via an external script and RDMS Synchronization (See ACS user guide)
