sachinraja Tue, 12/22/2009 - 20:54
  • Red, 2250 points or more
Hi Mitang
Cisco has  3 priviledge levels by default: (from CCO):
privilege level 1 = non-privileged (prompt is router>), the default level for logging in
privilege level 15 = privileged (prompt is router#), the level after going into enable mode
privilege level 0 = seldom used, but includes 5 commands: disable, enable, exit, help, and logout
You can define commands based on the level of access needed on priv 2-14 .. for eg network mgmt team can be specificaly given priv 2 - with show int commands etc... you can view the level of a logged user using the "show priviledge" command...
Hope this helps.. all the best
Raj
