32-Bit AS
Answered Question
Dec 22nd, 2009
We have 32-Bit AS no. , which is not supporting on any of our router/L3 switches cisco devices.
Kindly Suggest ..
Correct Answer by Eugene Khabarov about 7 years 6 months ago
What is your router/switch model?
You need BGP Support for 4-byte ASN  feature.
Update:
You beat me. Not only on these models, but also on:
1941, 2900, 3900, 12000, 7600.
Please reate if this helps.
Eugene.
Overall Rating: 5 (1 ratings)
csawest.dc Tue, 12/22/2009 - 22:47
Dear Sudhir,
You hv 32 ASN so that is 4 byte BGP ASN ok
so you need 12.4(24)T IOS for this, it is sopport 1800 , 2800 , 3800 Series Router only and 6500 switch.
which router/Switch are you using at present ??
Vaib...
Correct Answer
Eugene Khabarov Tue, 12/22/2009 - 23:01
  • Silver, 250 points or more
Update:
Eugene.
sudhir.bhagat Tue, 12/22/2009 - 23:18
Hii Freindx,
I was trying on cisco 7613 router / Cisco L3 Switches 4500 series & 4900 series ,  also tried on cisco 7200 series router.
Eugene Khabarov Tue, 12/22/2009 - 23:36
What is you sup/rsp for 7600?
For example, you can use this ios'es for rsp720:
12.2(33)SREADVANCED ENTERPRISE SERVICES SSHc7600rsp72043-adventerprisek9-mz.122-33.SRE.bin1024256
12.2(33)SREADVANCED IP SERVICESc7600rsp72043-advipservices-mz.122-33.SRE.bin1024256
12.2(33)SREADVANCED IP SERVICES SSHc7600rsp72043-advipservicesk9-mz.122-33.SRE.bin1024256
12.2(33)SREIP SERVICESc7600rsp72043-ipservices-mz.122-33.SRE.bin1024256
12.2(33)SREIP SERVICES SSHc7600rsp72043-ipservicesk9-mz.122-33.SRE.bin1024256
For 7200 you can use this ios'es:
12.2(33)SREADVANCED ENT SERVICES W/SNA SWITCHc7200-adventerprisek9_sna-mz.122-33.SRE.bin51264
12.2(33)SREADVANCED ENTERPRISE SERVICESc7200-adventerprisek9-mz.122-33.SRE.bin51264
12.2(33)SREADVANCED IP SERV W/LAWFUL INTERCEPTc7200-advipservicesk9_li-mz.122-33.SRE.bin51264
12.2(33)SREADVANCED IP SERVICESc7200-advipservicesk9-mz.122-33.SRE.bin51264
12.2(33)SRESP SERVICESc7200-spservicesk9-mz.122-33.SRE.bin51264
Please rate if this helps, Eugene.
