12-23-2009 12:21 AM
Dear All,
I am having a 5510 ASA using IP-SEC VPN for remote users. I want to send all the parameters preconfigured for VPN client.
How can i save the configuration file and send to a remote user?
Solved! Go to Solution.
12-23-2009 05:55 AM
Configure the vpn profile in your vpn client, then send them the .pcf file located in Program Files/Cisco Systems/VPN Client/Profiles directory. Then all they have to do is import it into their client.
12-23-2009 05:55 AM
12-27-2009 11:38 PM
Dear ,
Thank for your reply but i solved the issue on the same day itself.Still i will rate you.
