LMS 3.1 Slow after integrating with ACS
Dec 23rd, 2009
Dear All, have any one faced issue of slowness after integrating LMS3.1 with ACS4.2. I dont know how can I resolve this issue. Is there any patch to resolve it...
Any kind of help will be very helpful.
Marvin Rhoads Wed, 12/23/2009 - 09:19
I'm using LMS 3.2 into ACS 4.0 and it actually seemed a bit faster after ACS integration. Nothing I measured but subjectively it seems faster. Both my servers are on Windows and the ACS is across the WAN from my CiscoWorks.
How do your devices fare with their ACS? You can debug tacacs at the router/switch level as one tool. I'm sure one of the cisco guys on here will point you to one of the many logs that LMS generates, possibly with debugging activated, to dig deeper there also.
