ACE port-channel number in 6500 chassis
lukaszkhalil
Hello
Does anybody know how 6500 assigns the port-channel number for ACE ?
Thanks in advance
Lukas
Gilles Dufour
There is no portchannel for the ace module.
This is a tengig interface.
For example, with an ACE in slot 2.
gdufour-cat6k-2#show mod 2
Mod Ports Card Type                              Model              Serial No.
  2    1  Application Control Engine Module      ACE10-6500-K9      SAD1020084Z
Mod MAC addresses                       Hw    Fw           Sw           Status
  2  0030.f275.b4ec to 0030.f275.b4f3   1.1   8.7(0.22)ACE A2(1.6a)     Ok
Mod  Online Diag Status
  2  Pass
gdufour-cat6k-2#show int tenGigabitEthernet 2/1 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: 7,10,20,30,31,40,60,70,77,100,200,203,330,1100
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Gilles Dufour
  2  Pass
Switchport: Enabled
Voice VLAN: none
Thank you for the explenation.
Does this imply the ACE module can only interface with the fabric at 10Gbps?  How is this to function up to the advertised (and license offered) 16Gbps? I'm close to approaching my 8Gbps license.
slc3-chr01>show mod 6
  6    1  Application Control Engine Module      ACE20-MOD-K9       SAD130*****
  6  001f.ca7b.5fc8 to 001f.ca7b.5fcf   2.4   8.7(0.22)ACE A2(1.4)      Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  6  Pass
The 10G name is just a name but the backplane connection is indeed 16G full-duplex to the switch fabric.
