Unable to get on the LAN
Dec 23rd, 2009
I have 2 Aironet 1300 AP  and had been working smoothly last 3-4 yrs, but now on the part of Non-Root end i m unable to get into the lan, with the following results
1. When during the boot  i get the following messages
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
link auto-negotiating....
auto-negotiation takes 10000 milli-seconds to complete
ERROR: timeout waiting for auto-negotiation to complete
ERROR: fail to bring ethernet link up
2. After the boot on the command "show ip int bri"
I get the following results..
Interface                  IP-Address      OK? Method Status                Protocol
BVI1               YES DHCP   up                    up
Dot11Radio0                unassigned      YES TFTP   up                    up
FastEthernet0      YES manual up                    down
Virtual-Dot11Radio0        unassigned      YES TFTP   up                    up
3. Also on the Http Gui i m getting the "Hardware Status = Down" for FastEthernet
I have checked the physical connectivies and seems to be ok to me......
Please can you assist.....
Thanks in advance
Shrikant K.
karpurshrikant Thu, 12/24/2009 - 02:02
Thanks for the reply....
RMA ----- Do mean return to cisco. I dont think as the device has been more than 4 yrs old.
Do u think its a Hardware Failure? as I have checked the cable and the switches as those are  properly functioning on the other network.
Thanks in advance
Related Content
