Jon Marshall Wed, 12/23/2009 - 08:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
quadrasystems wrote:
Does the WS-C3560G-48TS-S has PoE (Power over Ethernet) or not. If not can it be upgraded to have it.
Thank you.
Rod
Rod
No it doesn't support PoE and as far as i know it can't be physically upgraded to support it. You need the PS rather than the TS version -
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html
Jon
sachinraja Wed, 12/23/2009 - 09:16
  • Red, 2250 points or more
Hi Rod
you cannot upgrade it directly, as Jon mentioned.. you can look at the URL Jon sent for the PS switches, or have a look at the new generation 3560 V2 switches which just adds energy efficiency which is looked up in datacenters today.. datasheet attached:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/data_sheet_c78-530976.html
Model to look for - 3560V2-48PS
You can also have a look at 3560-E if your requirement demands... 3560-E are a little expensive for the fact that it supports 10 G uplinks
3560-E datasheet:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7078/product_data_sheet0900aecd805bac22.html
Model to look for - 3560E-48PD
Hope this helps.. All the best..
Raj
