Access list in switch
Dec 23rd, 2009
I have two Vlans configured in our 4507 switch (IOS). Vlan 1 as company vlan and Vlan 2 as vendor vlan. I would like to configure access list(s) to accompolish the following rules:
Vlan 1 have full access to Vlan 2 (to the whole subnet or only few IP addresses).
Vlan 2 have no access to Vlan 1 at all.
What are the best way to have this done? Any suggestion will be appreciated.
Happy Holiday!
Panos Kampanakis Mon, 12/28/2009 - 16:00
Applying an ACL on a vlan interface will only have the ACL kick in if packets are L3 routed on the switch (hit the vlan SVI).
What you want is a Vlan ACL (VACL) explained here http://www.cisco.com/en/US/docs/routers/7600/ios/12.2SXF/configuration/guide/vacl.html
Here is an example:
Router# show ip access-lists net_10
Extended IP access list net_10
    permit ip 10.0.0.0 0.255.255.255 any
Router# show ip access-lists any_host
Standard IP access list any_host
    permit any
This example shows how to define and apply a VLAN access map to forward IP packets. In this example, IP traffic matching net_10 is forwarded and all other IP packets are dropped due to the default drop action. The map is applied to VLAN 12 to 16.
Router(config)# vlan access-map thor 10
Router(config-access-map)# match ip address net_10
Router(config-access-map)# action forward
Router(config-access-map)# exit
Router(config)# vlan filter thor vlan-list 12-16
I hope it helps.
PK
Related Content
