12-23-2009 09:17 AM
Hi ciscoteam,
i have lms 2.6 and i am trying to do a netconfig job via rme >tools>netshow>netshow jobs>create -- to execute the commands "show pas vsa statistics and show crypto eli
Initially i got the error ERROR:RME_CDL1045:Pre-Device deploy operation failed, Device not found in RME..Then i stopped the ciscoworks services and rmedb password has been resetted. Later on I deleted the device in common services and added it again. Then i did an update inventory thru device center and again tried to do a netconfig job. There i found that the job has been failed with the error message as " status->failure, Protocol used->Telnet, Message->Deploy command partially failed. When i click on the "Failure" link, i could see that output for both the commands were showing properly in the window..
Can you please help me on this as i am failed to understand the problem..
many thanks in advance
~pr
12-23-2009 09:42 AM
Post the output of the command as seen by Netshow.
12-23-2009 04:45 PM
12-23-2009 06:00 PM
Screenshots are not helpful. I need the full output in text format.
