Menu-structured local speed dial list in CME
Dec 23rd, 2009
I have a customer in a CME 7.0 deployment that wants to have multiple options on the local speed dial option under Directories.  For example, the first file accessed (speeddial.xml) provides a menu of choices for multiple speed dial lists.  Here is a portion of the speeddial.xml:
<CiscoIPPhoneMenu>
<Title>NOROP Speed Dials</Title>
<Prompt>Choose an option</Prompt>
<MenuItem>
<Name>Priority Numbers</Name>
<URL>http://10.10.10.10/Priority.xml</URL>
</MenuItem>
<MenuItem>
<Name>EMS</Name>
<URL>http://10.10.10.10/EMS.xml</URL>
</MenuItem>
<MenuItem>
<Name>Air Services</Name>
</MenuItem>
</CiscoIPPhoneMenu>
The file seems to be working, but when it calls the individual XML files, I am being prompted for login credentials.  Is there a way to disable the authentication?  The files reside on the router (10.10.10.10) in flash and I have disabled 'ip http authentication local'.  Thanks in advance for any assistance.
