The agent extension is out of service. error
Jonathan Schulenberg Wed, 12/23/2009 - 13:23
  • Cisco Designated VIP,
    2017 IP Telephony
The most common cause of this was the agent's phone restarted or a CTI interruption occured. This is typically something to start troubleshooting on UCM side. The CAD Troubleshooting Guide says essentially the same thing:
Problem The agent’s state changed to Not Ready for no apparent reason.
Symptom. In some situations, an agent’s state may change to Not
Cause. To determine the reason, check the reason code:
..other causes removed...
■ If the reason code is 32759, the agent’s state became Not Ready
because the phone went out of service. Check to make sure the
phone is still functional and that you can call the phone directly. If
everything seems fine, it is most likely a temporary problem and the
phone has since recovered. If the phone is still down, it is most
likely a Unified CM problem. Please consult Unified CM support.
Solution In many cases, an agent’s state becoming Not Ready is not a serious
issue. Simply click Ready to change the agent’s state to Ready.
To determine the reason code, do one of the following:
...other solutions removed...
McsePhoneguy_2 Fri, 12/25/2009 - 16:48
Thanks Jonathan,
It seems to happen fairly often on various phones and doesnt have a geograpic boundary.
Could be local phones to the UCM or remote users on the network.
It has been happening for 2-3 days randomly.
I will check out the guide.
Hopefully I can reach some conclusions as Im having to work until I repair it.
So far since Wednesday since on my vacation in FL trying to visit my mother.
Any additional ideas are much appreciated.
Tanner Ezell Mon, 12/28/2009 - 12:44
  • Silver, 250 points or more
David,
I've encountered this error in the past and it seemed mostly related to the wiring to the phones. Try having an agent that is having issues switch to CIPC and see if the error continues. Remember that phones are especially sensitive to bad wiring.
